Update on wiring and battery almost done!
why didn’t you put 1 more battery on each Series ?
Mainly a weight preference I want to keep the board around 30lbs max so It can my daily driver
Why no phish paper
He’s installing that tonight! Will be updating soon
Because it would raise the profile…I have the same enclosure on a xapham with a 12s9p.
Fish paper, Kapton tape and shrink wrap will be added soon
Gotta keep that weight down bro ;p
Hey guys! Was wondering if these 405 belts (15mm wide) are fine for these 67 teeth pulleys. They seem a little thin, is this ok?
It’s fine. If you do experience belt skipping you might want wider ones, and a wider motor pulley.
Let’s hope that won’t need to be done lol currently working on the griptape before I post the final finish
15mm wide dual belts should really be plenty if the tension and alignment are correct.
Nice build man and those @Tony_Stark (RadiumEsk8) mounts are gorgeous!
Yes those mounts are delicious. But you might wanna check that the motor shaft circlips aren’t catching on rthe opening in the mount… i needed to adjust mine.
I believe Liam is making some motor spacing plates to mitigate the problem for those who don’t wanna hack their mounts with a router
Lol if you’re watching J-Bo, you should know that my name is Glyphs
Indeed that was a design issue for motors with protruding circlips as the mounts were originally designed for maytech sealed motors, however I have now updated the design with a wider slot and created a 3mm motor spacer disk that solves the problem for any existing customers. Thanks @glyphiks for bringing the issue to my attention
Hahaha okok ur right, i just sometimes watch him and when he mentioned glyps i laughed my ass off, i think at first he even mentioned you as surferofdirt first
Thanks sir!
