Hi. My unity has unfortunately just broken (the positive and negative wire snapped off the pcb) so I’m in need of a replacement.
What have u got?
I’d really like either
Another unity/ Tenka, spintend, stormcore etc etc?
Any help appreciated thx
Are you unable to fix this yourself?
The pcb has literally snapped off . I’m not sure where I would start
Oh lmao
How about a DV6 dual 100a?
Do u have one for sale ? / what’s the spec ?
if he’s not offering, I have one I’d sell
What voltage do they run up to?
I’m have a stormcore 60d for sale - $275
depending on the PCB, sometimes there is still a bit of the contact patch on the side that you can solder to. If it is already broken then there is no harm in trying it.
I had a similar issue when soldering to flexible pcb where the contact are would often break off. The connections would be more sensitive to movement but that could be fixed with epoxy to hold the wires still. It might also limit the current that the controller can pull but less current and working is better than it being completely trashed.
the MakerX DV6 can handle up to 12s or 50V with headroom for voltage spikes. it can do up to 100 phase amps per side.
Mine is for sale, it’s new unused for $200+ shipping
I have a Unity I could part with. Used for a total of about 4 minutes on a test bench. Still have the box and no connectors have been changed.
This is one of the original pre-order units.
$240 (USD) plus shipping from Canada.
dude you could totally just resolder the power leads
Just sand these areas to get the copper visible then solder the wires.
Then you might need to dremel out the heat sinks slightly to make room for the wires.
Edit:
there seems to be a triangular area of vias. Don’t sand on those.
