I was going through some old boxes, and found some Evolve parts that someone could use…
2x Evolve 300mm stock GT3 Belts - Those are for AT wheel setup on GT or GTX setup - NEW
2x Generic 300mm HDT5M Belts - Same as above, but not original, used for about 50-100kms
From my readings (no prior knowkedge, was doing quite a bit of reading up on this yesterday), I think you might be better with 10a for a 7.5a charger.
Feel free to correct and educate me if I’m wrong
20 - 30% more is fine too. I say 50% because I know first-hand sometimes after your board is done you might start investigating using a faster charger, and that’s one less thing to worry about.
If it is a LingYi single drive, it doesn’t matter the voltage (up to 10S I believe) because you just have to resolder two points.
I would be intrested in buying it off you if it is a Lingyi SD.
Anyone in the us got a 5° angled riser pad? I’d buy one online but most of my recent purchases have taken a week to be fulfilled… Hoping to find someone here who can get it out the door a bit quicker
