Naw I don’t have a use for trucks amd motors atm. Those motor overheat too fast for what I’m doing lol.
I have an old set of Trampa Infinities if he’s interested. They need a bit of maintenance though. One needs springs and dampas. Both probably need new kingpin bushings.
Longshot I know, but does anyone have Hoyt Puck Series 1 (early ones) thumbwheel return springs? Specifically the really weak ones. I like those a lot better and the most recent Hoyt Puck 1 that came in had the newer stiffer springs.
I’ll take circular thumbwheels too if you’ve got them.
Hoping that someone has some dead Pucks around that they haven’t tossed yet.
Thanks,
I don’t have parts, but I have a series 1 puck I’m not using
i uh… might actually have this. i’d have to go diggin.
Thanks for the offer, if FessyFoo’s spring isn’t the right one I might pick this up, do a spring swap and then send it back to you if that’s ok ![]()
Anybody have two 10mm Boardnamics axles they’re willing to part with?
I’m looking for somе Logger module:
illoger
Freesk8 Robogotchi
Metr pro
Minnie
Anybody have a 14s charger? Don’t really care about amps, could be low. But probably should be below 4a for this 14s3p. Trying to see if this guy will work bc my lil 12s2p might be fried…
Oh and charging port appears to be a GX12-3 aviation connector. Might be the GX16… hard to tell.
Edit: also does anyone know if this is even a Bluetooth BMS?
I think that’s just a normal 3 pin XLR jack (of this style)
And I’m pretty sure that small blue PCB on the top there is a bluetooth module
I second this
Ah I see. Well then hopefully someone has one of those chargers ![]()
still can’t connect with the module ![]()
You can use any charger, just need to make an adapter or solder the right plug on
Another good tip/precaution is even if you get a 14S charger that comes with an XLR connector already on it (which are out there, common connector choice) still make sure the wiring polarity on the charger’s XLR pins matches how it is on that jack.
I have a new one of these, don’t have plans for it and willing to sell below retail price. LMK if you want it. (USA located)
Anyone have an eboosted subsonic gt40 single stack enclosure lying around?
@ andoug Try @abusfullofnuns he may have one or two . . .
I paid him for one and then he disappeared ![]()
