Just in case you are looking for 295mm belts in the future, boardnamics sells them for like $5 and free shipping
Kinda stupid, but im looking for a 6s1p/7s1p pack for this abomination: https://stacksocial.com/sales/urban-e-skateboard-premium-v2. Battery pack burnt out after the first charge (I paid 50 bucks for this thing, not 125). I was considering lipos but I donāt have one of those expensive balance chargers. If anyone has a cheap tiny pack like that, Iād be interested in buying it. Theyāre pretty cheap (I think) so Iām posting that here. THe original battery was a 7s1p 2200mAh
Need some 36T or 38T Kegel pulleys, have 32T, 36T and 38T ABEC pulleys to trade if needed.
I guess 40T would be too much?
Im concerned about overvolting the cheap ESC. It has a 6s and 7s operating mode, and obviously not programmable. If overvolting by a few volts like that is not a big deal, iād be happy to look into that. but the enclosure is too small. I would need 18650s. It only draws 350w, so like a small 30q pack would work fine. I have an mboards (yeah eww) 6s2p. but itās wayyyyy too large.
Typically there is a solder bridge that switches between 6/7/10s, I can made you an easy 10s1p pack if youāre State side
I have the 3DS 40T pulleys, on a different build. Really need 36T or max 38T for this one, but thanks for the offer!
You can always increase the motor pulley size.
Using some old evolve motors, canāt seem to find other than the 15T motor pulleys for that kind of shaft. But then I would need new motor pulleys, belts, etc, and it would be easier to just order some new 36T pulleys.
Unfortunately itās only 6s or 7s
I can sell you a couple pre welded but BMSless 6p staggered 35e packs for really cheap if you want, pre terminated with an XT60 but no wrapping or balance since I donāt have any 6s hardware and thatās where a lot of the cost comes from
Where you located as itās easier to help once we know that
New York, US
Isnāt this dangerous?
The problem is nobody has a 7s BMS because they basically donāt exist, and Iām not sure how comfortable I feel using a lithium battery without a BMS
I need 7s as I need a higher voltage. Iāve tried 6s with these motors and even just a bit of extra voltage goes a long way
Iām a fucking moron, if I donāt bridge either of the connections itās 10s⦠im so STUPID
7S BMS are right here
