Can’t seem to find them, maybe I just suck at navigating their site or they don’t offer them anymore.
This is for 20700/21700 cells
Lol when browsing their site in dutch the same item is advertized as 20700 only.
I guess 1mm doesn’t make a big difference…
thanks man!
Well that’s pretty weird…
Yeah the difference won’t be much xD
looking to borrow a spot welder in the uk?
anyone
also looking for those hexagon grip tape pieces?
do you have to cut them?
I cut out some by hand and then the next day I saw Torqueboards release some on their site . 10 bucks for a set, if that’s cheap enough. Or if you know someone with a laser cutter…
dont know anyone with a laser cutter thing is torqueboards is in US im in eu
guess might have to do them if no where else
ohh my bad, didn’t realize you were in the eu
I have a whole box of them, how many u need. just pay shipping. im in HK
but mine isn’t the big hex like the one Dex is sending, its slightly smaller, like those that comes with the BKB tayto kit.
Mine also had the same problem before, but I tried to clean the deck surface and apply little bit of heat to the hex just before applying seems to hold it slightly better, but overall those hex don’t stay on for that long
I tried clean. Heat is an interesting idea. tx.
only little bit tho, enough to soften the glue a bit and let it cool down by itself while u r working on other things, usually just few mins will do
thanks but getting a custom grip tape done in the end
thanks though
looking for keyway in the uk anyone?
thanks
You want a slot for a key cut into something? Check a local machinist.
Sorry can’t help myself. particularly pedantic pet peeve
I know you want the standard 3mm key to fit in the usual keyway On the motor shaft.
Your literally like my dad
Sorry I meant to say I require a 3x3x18 slot in order to fit into the shaft belonging to a motor
Lee, moon, Ben?
It’s fine just got from @anubis
