Wanted - dave ga complete
Yesterday is sort of difficult to achieve with your time zone. Plus, I still have important developments to do. :slight_smile: I should be able to send the first samples soon though. All depends on the speed of the China post.
Its all good, Im just messing with you :). I am looking forward to it, when you get ready to ship just let me know the cost and its done. Great looking product.
@janpom how are you dealing with dual setups? just multiplying data or reading both over CAN?
These new screens looks really good
Give me… give me now… :wink:
I don’t have reading over CAN implemented yet but it’s on my TODO list. I’m still deciding how to best display the data. I’m leaning towards aggregating the two (or 4 for 4WD) values to keep things uncluttered. For stuff like Wh in/out, it makes sense to take the sum. For input voltage readings or rpm, take the average. For max amps or temperature, take the highest value.
It looks fantastic, I’d definitely be keen to buy a couple once you’ve got it all figured out!
Thanks. I think we’re getting close to having the final product designed, including the aluminum enclosure. It will just take time to get them manufactured.
That’s a good approach
Are you running out memory yet? If not there is no problem to have a bunch of screens that can be enabled or disabled on the settings, for example, it you testing if your motors are overheating have a screen that shows only the 4 motor temperatures, and so on
There’s 4MB of flash memory on ESP32, which is plenty. And yes, I agree that more screens can be enabled and configured in the settings. It’s just a matter of implementing it and it’s not terribly complicated. I still have some decisions to make about data representation though to account for all possible setups up to 4WD, including dual Unity, four single VESCs, and Unity + two VESCs. Unity complicates things since it’s different from two individual VESCs in many ways.
Just use COMM_GET_VALUES_SETUP command and you’ll have the sum of all VESCs without asking over CAN.
However, the user needs to activate the CAN message 1_2_3_4_5 on each slave.
Anyway, I’m impressed how far you’ve gone in the dev !
I’m curious about OTA FW update ! Need to learn more on it.
I’d love to test one of the new ones!! The first one was awesome in every way!
Yah great stuff have been playing with ESP32 boards for work side projects too and nice they have split partitions in the memory for a core system that can get OTA updates and separate partition for the user program. Gives similar deployment functionality as photon (from particle.io) I imagine, but we had to wipe out the second partition to load our Bluetooth scanner programs onto them, written in a couple days for a hackathon though so sure with some time dedicated can do a better job managing the compiled program size.
There’s also dual core versions if you need it for some reason.
Nice, I will start to look at the code
For now is just one type of display right? I will try to fork it to use a 128x64 OLED and then we can see how to merge it
Just to be clear, the new DAVEga is not open source. It’s a complete rewrite in micropython.
You can definitely make the open source DAVEga code work with 128x64 OLED though. In fact, I have already done it for 128x32 OLED as an experiment. The branch is a bit outdated but it should work well as an inspiration: https://github.com/janpom/davega/commits/display_refactor
No problem, I didn’t realize it had changed
Then will probably get a complete from you
That’s neat. I wasn’t aware of that command. Thanks. Maybe that’s good enough for v1.
I think I’ll eventually want to implement the asking over CAN anyway to get stuff like current on all motors, which the COMM_GET_VALUES_SETUP doesn’t provide (if I’m reading the code correctly). Plus, it seems pretty straightforward. The VESC communication protocol is very friendly.
Also, the COMM_GET_VALUES_SETUP was only added in FW 3.42 and probably not backported to Ackmaniac’s FW?
COMM_GET_VALUES_SETUP has been added in the 3.48.
Not sure that Ackmaniac implemented it.
It’s 3.42 according to the CHANGELOG: https://github.com/vedderb/bldc/blob/master/CHANGELOG#L115
Oh sorry, you’re right !
Well, I don’t know why I thought it was 3.48.
I need to change my VESC library then… :smile:
Thanks for pointing me that out.
