Wanted 2 6374 motors Uk
Yep, 16awg
10char
It’s about 5$ extra for the right temp sensor if you order them from China. Sure that as well depends on the factory you get them from, but shouldn’t be more.
Still scratching my head :grin:
About what? You have plenty of options now :sweat_smile:
found these, not sure on the shaft its d shaped will that be ok?
if its ok with everybody will order these 170kv?
It has 10mm shaft. Just something to note when looking for motor pulley.
thanks ben
do pullys go to 10mm?
They do.
https://www.beltingonline.com/18-tooth-htd5-pulley-18-5m-15f-7775?zenid=k7akpd0v6vd0j7p72ms6slun91
These guys are pretty good for custom pulleys.
this is also 10mm d shaft
This is the only pulley that fits those C6374 motors I could find, unless you want to use a rounded one and leave the D shape part hollow. Its a pretty deep d cut too.
These are the same base motors I stock but be aware that when ordering 1 to the UK it will cost more than just buying from a UK source, because they will post via royal mail who charge a £8 base fee on all customs chargers.
I am also now stocking those battleharderned instead of regular.
hay thanks very much for that
Dickyho carries D-shape pulleys as well.
