Having trouble with a vx2, it connects with the stormcore but doesnt show battery and no throttle respons, i have tried everything, switching the wires, go through set-up on the remote and vesc tool 100 times, i have checked all wires and they seem fine,
anyone know what the issue might be??
Tried contacting flipsky allready btw but they just go inn full circle….
Also even if it’s connected, go into the remote settings and put it in pairing mode. And select fesc in the remote settings on the remote. It’s all about remotes and remote things.
Hi, how do you get the throttle curve to show up on UART? My remote (VX2) is connected to my board and I can control the motor, but in the vesc tool on the UART app page it shows nothing other than the baud rate:
in app settings (general) there should be an option to make it ppm, ppm +uart, and uart. if it’s selected as uart “vesc wand” should show up as an option in the menu
