I hope this is in the right section, here goes!
Vesc Data - Hi Guys, Wondering if you can help me. Ive recently been out on a ride which I have asked the Vesc Tool to download a data log of my ride (in the developer section). I have now imported this into a readable format on Excel which provides graphs etc etc. However when I convert my speed from Miles per second to Miles per hour it is telling me that I peaked at 40mph! This definately didnt happen and wondered how I would ensure that the data it does record is accurate? The voltage and the distance is bang on! I am happy to share my data with you if you want to review it.
Did you set your wheel size and gearing correctly?
I am guilty of forgetting to change tire sizes and getting weird range results
Don’t forget “motor poles” too.
Not all of them are 14.
Yep,
Everything set 200mm wheels with 9t Motor pulley with 44t Slave. On a set of moon drives! I cannot work it out. I suppose I would need to check the motor poles.
Unless I was just going that fast and I didnt realise
