Having trouble getting my input to drive both motors, using 2x TB escs. I don’t know if I’m derping out, just stoned, or missing something. Budget build so no bluetooth, that usually the easy fix for me. What settings should I be using?
Nevermind, totally did derp out. Can_status message mode was disabled on the slave.
Happens to all of us. I built an entire build once with the wheels turning the wrong way and the trucks on backwards.
make sure each esc has it’s own can ID.
If you set them to the same, after about 30min one esc will stop working until you reboot.
I did not figure it out on my own.
