Okay, so I uploaded the bootloader as explained in the tutorial.
However, I didn’t use the .hex file he linked since the link is broken, so I used this one instead:
Now the VESC shows only Blue LED light (there should be also a Green one) and when I plug
the VESC to my PC nothing happen, it can’t be recognized. What’s wrong?
I will take a look at that, but I think the issue is that I uploaded a .hex file that only contains the bootloader and has no firmware on it, does it make sense?
With swd prog you upload the FW and bootloader in one hit. You need a working ESC though. That ESC can be bricked, but you need to be able to connect to it. The ESC becomes a programmer to program other ESCs or dongles or …
