How do I donate directly to @Deodand ?
Yeah, I was about to say the same as @tipsy did, right now you are being like the employee that sees a problem, but doesnât actually do anything to fix it, they just point and shout at it.
I am all for catching issues when they are discovered, but whereâs your solution? Why shout negative feedback without offering a solution? Your solution may be your own competing product, but without proof of it, the general feeling is that youâre just being a dick lol
I understand most of what you are saying and people can say what they want about Frank and the whole ordeal of VESC but they are doing good work here, and frankly (lol) any positive updates in the software are great news for the common end user that wants a reliable speed controller
I see what you did there ![]()
How are the brakes?
As I said, working on getting the most accurate measurements as possible and keeping the firmware light and efficient so fewer things can break. Already made notes of future revisions so hardware circuitry can shut down the power stage in case of fault and cut software out of the picture during fault conditions. I hope to eventually fit it in 128kB of flash. This keeps costs down for the end user and helps keep software bugs from rearing their ugly head.
The current sensing stage is 25% of the BOM. I spent several days designing the 3.3V supply to minimize ADC noise.
@Deodand @Trampa is there a risk that motors lock up due to a faulty measurement when using HFI?
I also didnât fully understand yet if the HFI is only active till a specific rpm like it is with sensors or itâs active all the time?
@Trampa @Deodand the question is inevitable, so Iâll be the monkey.
Can / will the Unity support HFI in future?
@malJohann I would expect a yes
Hi Andy, HFI is only used to start up the motor. As soon as the rotor has some speed, BMFs are used to track the rotor (as usual). If you would get trouble, only at speeds below walking speed .You also hear the transition, The high frequency noise cuts out after transition.
@malJohann : Unity is a two battery side shunt design. Three shunts work best for HFI. Three phase shunts are king, three battery side shunts are also OK. @Deodand, correct me if I am wrong here. You designed the Unity.
@Gamer43: The VESC-Tool is OS and neither software, nor HW layouts are a fixed thing. VESC-Tool is not trying to compete, we try to build an awesome tool through collaboration. That is why I contacted Jeffrey and organized a meeting with Benjamin. If you are unhappy about things, github offers plenty of options to contribute. It can be code contribution or a qualified comment: Issues ¡ vedderb/vesc_tool ¡ GitHub
the never-ending story⌠i watched the movie⌠didnât like it muchâŚ
but what I DO like is @Deodand and B. Vedder working together for the common good! If only @Trampa wasnât the middle manâŚ
Frank one more question, from Benjaminâs video I understood that the HFI is limited to around 40A as the stator saturates. Does this mean that I can max pull 40A motor side when starting off and after the vesc doesnât deliver more power? I worry that that isnât enough if you start up on a steep hill or when your wheels locked in a mud hole or any other bad place.
Depends on the motor. Bigger motor more Amps. It works pretty well. You can give it a try. Switching back to HALLs is only a click. Usually starting on a hill is more of a traction issue, not a power issue. Keeping traction requires throttle control anyway.
Whatâs with tha initial sound?
That is the high frequency injection. The motor becomes a loudspeaker for a second.
Ahh⌠is the that beep sound a feature or a byproduct of HFI?
FW 3.63 and 3.64 should not be used. The new Tool will shoot a warning! Especially in combo with metr there is a potential safety issue. 3.65 would be the way forward. You can download the FW here and install it via the custom FW upload tab. https://github.com/vedderb/vesc_tool/tree/master/res/firmwares
Listen to trains.
It is called High Frequency Injection, a method to determine the stator position. Obviously a by product. On three motor side shunt designs Vedder managed to shift the noise into a region that is not hearable for humans. Jeff and Benjamin will keep working on HFI and the sound will change over time. Lets see if it can be completely eliminated one day.
Cool stuff.
I would leave this as a cool sound for the community.
