it was sensored bldc
Sounds like a friggen jet. Love it. Which ESC?
Fsesc 6.6
Hopefully I donât derail the thread though. My carpet loved it at least.
that sound is freaking awesome!
You can increase the HFI erpm cutoff to whatever you want, but I donât know if that will cause rotor tracking issues by not using back EMF for high speed position tracking⊠but I think it might make the sound you want to hear happen continuously
Iâll have to check which max erpm could be ok before disengaging it based on speed⊠I think for up to 30km/h, after that wind and ambient noise should prevail anyway for awareness so back to normal FOC silence.
Thanks for the tip !
Edit : On another note, does anyone know if there has been failures reported on the VESC 6 plus integrated switch ? I think yes but not sure. Apart from it, what are main différences with VESC 6.4 ?
BLDC for the win
Donât FOC it up man.
After doing maintenance to my board with ESCapes, I figured why not try out the new HFI on the VESC Tool. Although, to my concern I am having an extremely long update time for the firmware? It is about 5 mins now and only around 20-25% compiled. Is this normal for this new 4.0 update? It never takes me this long on Ackmaniacâs tool. Just connect, firmware loads quickly, and I am onto motor detection.
Just want to make sure that something isnât wrong with my ESCapes, bootloader, etc.
Someone else was having this problem above. What firmware are you coming from?
Edit: this
this â
F*&K of course I missed that while reading most of this damn thread. My fault and thank you.
So just wait huh⊠Dammit!
Either wait or cancel. I canceled it after 15 minutes and 8%
LOL, same here. Even under the âstay at homeâ status, I canât wait this damn long. I will just stick with what I know. Back to Ack.
Iâve been using Ack ever since the godfather himself @mmaner recommended it to me.
Since the stock vesc tool wasnât able to do the simplest tasks (connecting CAN) i switched and never had any regrets.
true, just wanted to check the sensorless HFI for my SK3s. You knowâŠnew shiny thing!
Since that didnât work either for me (also sk3) i switched back yet again
Well shit⊠thank you for saving me hours!
HFI working good on my two sk3 so far! i adjusted the values manually.
