Hello,
Does anybody have VESC Tool software that supports 3.53 firmware?
I think it would be 1.07 VESC tool not sure about it tho. I found out that the .bin file when flashed on my previously non working ESC with a discovery board somehow cancelled all the errors but I need the right software to run detection with 3.53 firmware.
did you try downloading the most recent version from
https://vesc-project.com/
the commit you are looking for is here
I think i have the vesc tooll from 1.08 upwards. Not sure if 1.08 supports 3.52 though.
Here you go. I have some versions on my pc, since when, I don’t know.
Oh thank you very much. Yeah the thing is my FSESC blinks red and doesn’t listen to any commands on some of the VESC tool firmwares. I found that it has no errors and works on some certain versions of the FW. Not sure where that’s coming from tho. I also tried the newest Ackmaniac tool and its working fine! The only problem I have with Ackmaniac is that it doesn’t support my FS bluetooth module and doesn’t display any info. Thank you very much tho! I’ll have to switch the Firmwares.
For any FW/SW compatibility check, you may find this doc useful :
I try to keep it updated when I have enough time.
A lot of work went into this I see. Thanks for your research!
