VESC Labs Black Friday Duet deal
Hey guys, little late on the post but just wanted to share we are running a little Black Friday deal €50 off the duet at VESC Labs.
We ship pretty much anywhere so if you are in the market for a high power dual controller for a mountain board or racing setup this might be a good controller for you. We don’t plan on running too many promotions so I would grab this deal now if you need it. Probably will run the deal for a week or so.
Thanks! If someone were comparing this to the 100d, what would you highlight as differences?
Great question:
  • Better Wireless connection with WiFi and BLE support as well as local logging since we use the ESP32 with 4Gb on pcb memory instead of NRF chip. Also will make for an excellent reciever for a remote that is in development.
  • Much higher upper limit on power, tested up to 200 amps which can even be sustained if something like liquid cooling block were used. The 100D will fault pretty repeatably around 130 amps
  • Better current shunt layout, better performance for things like sensorless operation and HFI.
  • Single large fet layout means less total points of failure from having just 12 large mosfets instead of 36 smaller ones with 3 in parallel. Not sure the exact impact of this in reality but I have to imagine it decreases odds of pulling a faulty mosfet or a weak solder joint on one of the mosfets.
  • GPS port connected to ESP32 so you can easily hook up a gps module and get gps data in your onboard ride logs.
Here is a little video Benjamin Vedder made showing some of this.
Dude, this is awesome. I had no idea you were making new vesc esc’s.
I love HFI, but most ESC’s do not support actually silent HFI “sHFI”, due to something about sampling rate and phase shunts IIRC.
Does the Duet VESC have the appropriate hardware to support running sHFI in silence, or does it have the high pitched whine?
Also, I see the duet rated to 22s. Would you say the safe limit for esk8 is probably 20s, or keep it to 18s?
Cheers!
How about to the d100s? Id love to see a competitor to that thing. Some of what you listed applies to this comparison too.
Mostly what I wanna know is how the thermals compare at close to 200 phase amps
The whine is the best thing! people in the office call my mountainboard “The Spaceship”
The Stooge gears whine is the real spaceship. :joy:
For silent HFI you want a single ESC with phase shunts. But in my experience most motors don’t start near as well as if you enable the whiney sound and Benjamin has said the same to me before. Depends on resonance of the motor I think.
That said you should try some of the new HFI modes. I find some of them significantly less annoying in sound quality and less loud as well. I will ask Benjamin which ones are worth trying we have an HFI wizard on our to do list.
20s should be solid, still early days to say for sure but all tests have shown these things to be surprisingly bulletproof.
This would be very nice to have.
