Yeah, if you want to discharge high amps you need size to deal with heat which sucks for most builds size constraints. If you used a much larger heat sink you could probably ignore the discharge ratings and use the medium sized BMS.
Not implemented yet, since it has to be also done on the firmware on the VESC side, but definitely possible
That will be a thing, it already is with DieBieMS using Metr
Still on beta, there was a shipping strike so not everybody got the beta boards yet, me included
Have you ever looked at the Github before talking shit? Lots of mergers and vedder responding to people implementations, 55 pull request closed, 9 still open and some with discussions going on about testing/modifying them before merging
This would exactly meet my expectations once implemented.
Itâd be far better to just connect the B- to the VESC power with a high-current wire (as we do now) and connect the BMSâs P- to the VESC with a small current wire.
When the BMS cuts power to P- then the VESC could see this and cut power slowly until off, but leave braking enabled.
This would ensure the BMS was still responsible for managing the battery, by itself, no matter how many VESCs were connected, and ensure that the large currents were still bypassing the BMS.
Itâd be win-win-win. Let the BMS manage the battery, but send the signal that somthing is amiss to the ESC. From a port that the BMS already has for this purpose.
Kind-of like this, but with the VESC able to see if the lights are on or not, and cut throttle if not.
I personally hope so see for a simple software implementation of BMS integration to the VESC. By this I mean for CAN equipped BMSâs which are able to communicate to the VESC, and when they notice something wrong based on a set of conditions (cell overheat, p-pack balance issue, etc) a command can be sent to the VESC to allow for reduced acceleration and braking only, effectively putting the board into limp-mode allowing the rider to get to safety.
That would be the best implementation imo, would effectively give us discharge capabilities through charge only BMSâs, while utilising hardware that we already have for the high currents that we run, whilst also keeping size to a minimum
Well, you can set it up for up to 200A discharge. So the current problem will turn into a cooling and connector problem (which will be fine for 99% since you never draw over 60A RMS for more than a couple of minutes; e.g. a 1kwh battery (13S, 20Ah) will only last 20mins on 60A RMS).
Also you can wire up charge and discharge separately and get the double amp rating (by separating charge and discharge mosfets and run each current only through one of the fets than through both). Then you have 120A discharge continousâŠthatâs >5kWâŠwhich will be around 10mins for a 13S 20Ah battery (like 13S7P). Cant imagine anyone can put down that energy with a mtbâŠ
Yes but there is no branch or release or tagging. So is impossible for anyone else to working on this or track change.
This codebase is not manage well at all.
Yeah, but letâs end this discussion here and focus on the topic of measuring cell voltages or this is another thread that will be turned into a shit show
Is no need for be angry word to @Winfly because he right.
Oh, so you can basically âoverclockâ these because the limit can be set as user wishes?
Too bad I ordered the lowest discharge version as I planned on bypassing it anyways.
There is nothing like overclocking or something. There are some mosfets in parallel (depending on the amp rating different numbers) and some shunts (also depending on the rating how many). The bms measures the amp draw via voltage drop over the shunt. And software will then turn off mosfets at set limit in software.
For the old â60Aâ version 200A was the limit you can set in software. But still the thermal design is made vor 60A continuous.
Well, order some mosfets and shunts (like from mouser or digikey). The 20A version is the same PCB like the 60A version but with less mosfets and shunts populated (hence the same dimensions).
We will have a smaller version of the DieBie in our Prject X board though.
Thatâs what I meant with âoverclockingâ - running more current through them than they were designed to sustain continuously. ![]()
Great Idea, thank you!
Lovely!
When will the first round be available?
We launch in spring
Seems to me like 2020 will be a big year for esk8 specific auxiliary parts.
I agree this is the future.
In my mind, a small battery pack monitoring device with canbus, maybe a display driver (i2c?) and/on audible alarm interface, with optional cell balancing, and optional balance lead passthru for external balancing.
If a control protocol gets implemented vesc side, it shouldnât be too hard to implement @b264âs idea with a small device between a dumb bms and canbus.
FlexiBMS + Davega X? Seen screenshots of this, not sure if itâs released yet. @janpom
DAVEGA X has DieBieMS support now. Not yet officially released. Iâm still testing it but itâs already working and Iâm happy to provide the firmware for anyone interested.
FlexiBMS still needs developments at the FlexiBMS side to be supported.
Yeah, that would be Ideal. I am actually getting a DaveGA of the batch which is currently in the works.
@janpom whatâs the rough ETA on my DaveGA X?
How far away is the flexiBMS from supporting the DaveGA?
Should I wait for that or try to get a DieBieMS?
