So, I am still in shock by what happened. But I will try to explain what happened so you guys can help me out with what could be the cause of it.
I recently got my FSESC dual 4.20. I hooked it up to my battery made by a professional builder with a bestech high discharge BMS. I then started the motor config in VESC tool. I use the 1.13 version. I did the motor detection in the setup Foc tab. Not in the motor wizard. However one time it said that I did not have the latest firmware, even though I had 3.57 on both the master and the slave.
It did the test and then I got some values. I did not like the values, so I rerun the tests. Nothing happend when I pressed run detection, even after pressing multiple times. So I ran the motor wizard, which makes you do it on both the master and slave on the vesc. Not both at the same time over can bus.
Master side worked fine and I got the values. When I started the detection on the slave side however, it cut off in the middle of it and the bms cut off the battery. So I had to press the switch and then press it again to give power to the vesc.
This is when shit got so fucking wrong. When I pressed the e-switch, something on the underside of my VESC started burning, like a damn firecracker. It kept going on for like a second and I was then left with a big soot on my desk as well as a probably completely unsuable piece of electronics on my desk. As someone with quite a limited income, this literally burned 150$ of my money in front of me.
I could be wrong but I believe I’ve read about killing canbus escs by turning one off before the other. @b264 has knowledge relative to this I believe.
Frederic, from electricboardsolutions. @EboardSolutions . But I am pretty certain that it is nothing wrong with the battery. I tried plugging it in to my other vesc, from maytech. It went fine without any fires
