Hey there. I have recently switched out a fsecs 6.6 plus with a Trampa Vesc Hd60. The entire thing is ppm controlled (GT2B, Master cho case). I run the antenna between enclosure and board (both carbon). The problem is i get cut outs. The board occasionally accelerates after letting go of the trottle and (also occasionally) the breaking starts/stops delayed. Can this be the enclosure?
Would it be better to drill a tiny hole in the enclosure and get the antenna out that way? Always open for better solutions, build or techwise.
Layout of the internals. on the left side you can see the antenna with just gets sandwiched and to the outside.
Like so.
