I’m planning to use a Boosted SR battery with a FOCBOX Unity. I figured out how to use an Arduino to make the battery think it’s connected to a Boosted ESC.
Anyway, I don’t technically need to use the VESC settings to set the high/low voltage cutoff settings because the battery has a sophisticated BMS that can handle high current.
Are there any downsides to making the voltage settings like 0 V min, and 60 V max? I indeed to cap the current in the VESC at around 30A.
