Looking for a used Hoyt St. Puck! pm
This is going to be the single most expensive Halo Board in the world…
So I stopped following, but have you tried fitting your unity in the haloboard? It’s gonna be a tight fit. I can’t even get a dual FS 4.2+ in there
Source: I have 2 halo board carcasses and can’t fit a damn ESC in there
Halo board beast is cutting it close
I think it’s fairly worth… Lol
It’s like gathering items that you know you’ll use later in another build… But just putting them to immediate use
FOCBOX is still in the mail, will update my original thread when I install it
Because you’d think it would fit, but if you look inside the compartment, it’s raised higher for some reason when you get into the esc space. But I can guarantee a 10s4p 18650 can fit for sure
I just find it that so much is getting packed into that board, it’s absurd how much more powerful it will be
Yea I personally hate it because it’s so goddamn stiff and short, but if people can build flexy eMTBs then… 🤷
HAHA take my money!
I mean I can make you a double stack or 21700 pack but you need to make the board THICC to have room
Na I won’t compromise the aesthetic.
TF?? 12S?? Uhhh. 12s4p for sure CANNOT work. I would’ve just gone 10s4p but I guess 12s3p…
You’re 100% limited to 18650 because it’s an integrated deck. There’s no way to make it fit anything fatter unless you raise the flimsy ass compartment cover.
I’d listen to master @ZachTetra
You could possibly make the unity fit if you removed the unity’s own heatsink and tapped holes onto a new plate to fit the halo board
I can do 2 lines of 21 cells, so the most cells is a 10s4p or 14s3p, but I need at least 3 cells of space for the BMS
I.e. 9s4p or 13s3p
WTB, battery pack with perfect fit and all the range. also please throw in hoyt puck.
Roger
Hence the thread
I can only do 2 lines of coke
