[USA] WTB 95mm+ Caliber/TB Motor mount
Looking for a longer motor mount for caliber/TB trucks, currently using a 70mm (center of truck axle to center of motor shaft), need one that’s a little longer. I have a truck clamp, so I could drill holes in any mount to get it to fit. Dickyho is selling these on eBay for $25 and they look good, I just don’t want to wait a month for it:
if you have one of these, or something similar, for cheap, I’d be willing to buy it!
Two things
  1. Boardnamics.com if youre using bn trucks
  2. Wrong sale category
fixed the category, and $70 BN mounts cost too much for me :grimacing:
Which trucks do you have exactly?
TB218s, TORQUE 218mm Trucks – DIY Electric Skateboard
shaped like this:
For tb218, they’re slightly larger than regular caliber 2. Boardnamics clamps don’t work and I suspect many others will have the same issue. Afaik you’re stuck with dickyho or TB
Welcome to the waiting room, I’m also currently waiting for mounts from dickyho. :slight_smile:
100mm +/- 10mm from @Boardnamics
I can confirm these dont work with tb218.
You probably need to ask for Caliber mounts when you order, I don’t know if that’s an option.
What about them didn’t work for you?
Caliber mounts always need to be filed or fit loose because cast truck hangers aren’t all the same size like milled ones are.
For one, those don’t have clamps available. Precision only as they’re larger.
Two,
TB trucks have a “taller” profile than regular caliber 2
Ehh, nothing a file can’t fix.
I file clamps all the time.
Forgot to mention it earlier, I have a TB truck clamp so I could actually use any mount if I drill a few holes in it
Welcome
