Located Portland OR USA
15t motor pulleys, 10mm D shaft, for 15mm belts - $10
Radium 78t pulleys - brand new never used, comes with bolt spacers. SOLD
Newbee 4GS 5:1 with Flipsky 6374 190kv installed, Luna 350 clamps - used a couple times, works great. $400 shipped in US.
Boardnamics XL motor mounts - Newest revision(motors can slide in/out for easy install without removing motor pulleys), comes with all hardware, used only for about 5 minutes. - SOLD
Moon Eskate 15 degree truck baseplate (fits all Caliber II style trucks), has Riptide pivot cups and 2 90a Riptide barrel bushings included - $80 shipped
Boardnamics adjustable baseplates, brand new, newest revision $50 for one, $95 for both
Boardnamics 6384 190kv motors, battle hardened, 8mm stepped shaft with keyway. Installed on geardrives and removed, never ridden. - $240 shipped
Boardnamics M1-AT 4.6 ratio gear drives, Apex/Luna mounts, brand new, never ridden. Was assembled and ran motor detection. Just install the motor gears on your motors and go. SOLD
Boardnamics BN270 hangers - SOLD
Boardnamics 48/33 split angle precision baseplates, ridden for 5 minutes - 65 shipped
TB110 72a blue wheels, used in good condition - $80 shipped
Hoyt St. 5" pneumatic tires/tubes/rims/pulleys with 10mm bearings, brand new(swap bearings if you have 8mm axles) - SOLD
Randal baseplates:
R-II 50* x2
R-II 42* x1
DH-35 35* x1
$12 each,
2 Riptide Randal pivot cups $10
Boardnamics kegel 44T pulleys, - SOLD
Boardnamics ABEC 40T pulleys, brand new - $50/pair
Boardnamics 40T pulleys without Kegel/ABEC part, $20 pair
Boardnamics caliber II 63mm motor mounts with all hardware and clamps, center distance 56-68mm SOLD
Boardnamics Caliber II 63mm idler motor mounts. Belt tension is adjusted by idler, fixed 90mm center to center motor distance. Modified mounts by cutting 27mm hole so motor can be installed and removed without removing motor pulley from shaft. Doesn’t come with clamps/hardware. $40
New belts
HTD295-5M belts, $3 each, 2 available
HTD275-5M belts, $3 each, 6 available
HTD325-5M belts, $3 each, 2 avaliable
HTD380-5M belts, $9 each, 2 available
Lacroix Hoyt midnight puck case, brand new $20
Newbee wheel bearing spacers 4x 22mm long x 10mm ID x 16mm OD for 10mm truck axles, $13 shipped
Riptide longboard 0.6" bushings:
93a red WFB Barrel x2
93a maroon Krank Barrel x2
96a grey Krank Barrel x1
90a green Krank cone x1
88a yellow WFB Cone x1
$4 each
Psychotiller Recoil deck, 40x11.1, 1" radial drop, 10 ply, Vicious grip, comes with enclosure installed using m4 titanium hardware. Fits 12s4p 21700, smart BMS and single VESC such as Stormcore 60D - used, $250
