Hey Guys!!
Looking to part out the Century I built a few months back. Looking forward to building a 4WD MTB for some Desert riding out here in NM. Everything is lightly used and well taken care of. All the components are used and under 150 miles total use. Willing to negotiate multiple purchases.
PayPal preferred! DM for additional Payment Methods.
Available for Sale Below:
1. SR + XTLA Drive Train
Surfrodz RKP, XTLA Mount with extra Press Fits, Bowery Surf ABP. Comes with king pins, and few extra riptide bushings. Uses Boardnamics 10-8 Stepped Axels - Red Loctited. Motors, wheels not included.:
$150 (USD) + Shipping:
SOLD - Not Available Unless Fall Through
SOLD eBoosted Century Enclosure
eBoosted Century enclosure. Has holes drilled for Unity power switch, standard barrel charge port, mr60 motor connections w/ fitting grommets, and hole drilled for a Davega.:
SOLD MBoards VESC and Antispark w/ BT Receiver
Used 50 miles in a single motor test build. Works good. PPM input soldered on. XT60 connectors all around:
SOLD Century CF Deck
Looks awesome, all holes original minus 1 hole to account for routing Davega. eBoosted did the inserts and hole drilling. CF version from eBoosted. Cut outs fitted for Unity Power Button, Standard Barrel Charger, and MR60 Motor Wires. Grommets included for MR60.:
SOLD 115mm Airless Tires w/ 45T Kegel Pulley
Used - Some marks on pulleys. Lots of life left on tires. About 200 miles on tires:
SOLD 6374 Flipsky Motors
NA:
SOLD Green Puck w/ Printed PPB and Clear Shell
Green great condition. My print jobs is meh but it works and nice change. Clear has scratches from a slide in dirt.:
SOLD 12s4p 40T Battery
12s4p 40T battery with LLT BMS and Standard Barrel Charge port. Charge port is fused. BMS bypassed. No charger included. Less than 10 cycles. Works well, balanced well. Not a seasoned builder but can see the quality is great. Unsure if I will sell because of inherent risk but posting for now. Listing will be priced at cell value and BMS value. Offering the buyer a 30 day money back guarantee.:
SOLD Fucked Up ATC 72T Rock Star II Pulleys
Spray painted. No use. Hardware included. If you can clean them, they’ll look great!:
