[US] [WTS - WTT] Flux Motion V1 Deck & Enclosure — $120
Hey everyone,
Up for sale is a Flux Motion Version 1 deck and enclosure. The deck has been customized — definitely not everyone’s style — but it should be easy to sand down and repaint, or just throw on some fresh grip tape.
The deck was painted black with stickers under a layer of clear grip tape. The paint has held up great with no noticeable scuffs or chips. The enclosure has plenty of surface scratches but no cracks or structural issues. Check the photos for the holes drilled for the charge port, power switch, and an extra switch.
When I got the set, I removed all of the threaded inserts and drilled straight through the deck. I was using thick foam gaskets at the time, and the compression of the gasket would made it so my bolts would push past the deck and poke through the grip tape in some spots. It just wasn’t working well. Mounting the enclosure with through-bolts has worked fine ever since and has never caused any issues with fitment or function.
Since the inserts were removed, there’s a small amount of space around some of the bolt holes. They were never filled, but the bolts still tightened down fine with the standard drill size that was left in the deck. If preferred, inserts could be added back in easily—just switch to a thinner or standard gasket setup and avoid using bolts that are too long.
The thick foam gaskets included were used to increase internal clearance, as the board was previously set up with a NESE-style battery. I can also include the original charge port that the enclosure was drilled for, though it doesn’t have much wire lead left.
Price: $120 + shipping
Ships from: Eagle Mountain, Utah
Trades: Open to trades. I’m currently building a Ram Board Paragon, so I’m interested in parts or gear that would fit well with that setup.
Note: Apex Air trucks and wheels are not included in this sale.
Let me know if you have any questions or want more photos!
