[US] WTS Like New Tynee 14S Ultra X Pro (UXP) w/ 2.8 Helical Gear Drive & LED Light Deck - $780 USD obo (6 Miles on Odometer) - Royal Oak, MI 48067
Tynee 14s Ultra X Pro (UXP) Electric Longboard w/ 2.8 Helical Gear Drive & LED Light Deck
Description: Just got delivered a couple weeks ago and took it on a few short rides and decided that I should have went with the Explorer Pro instead based on my style of boarding. Tynee doesn’t accept returns so my loss is your gain.
I just paid $989 for it so please no low ball offers.
I prefer local pickup but can ship it for an additional $100.
Text or call me @ 202-577-4093 for more information or to arrange to see it.
Willing to trade for a Tynee Explorer Pro with either belt drive or gear drive.
Cheers, Chris
14S (58.8V) High Voltage Power System
More power, more efficiency, no voltage sag.
The Tynee Ultra X Pro uses a 14S (58.8V) high voltage power system. Compared to other boards that are 12s (and 50.4V), the 14S battery we use supplies more torque, quicker acceleration, a higher speed, greater efficiency, less voltage sag, and less generated heat. As a result of all of this, the battery in our Ultra X Pro provides amazing performance and outstanding durability.
14S Samsung 50S 504Wh Battery
90A discharge. More charging cycles.
The battery is the most important and most expensive component of an electric skateboard, so we chose the best available—Samsung 50S battery cells. It can discharge 90A current. While many brands use cheap, unknown battery cells, Tynee insists on using high-quality Samsung 50S battery cells, which will safely give you better performance, greater longevity, and more charging cycles.
Hobbywing 14S V7.0 9028 ESC
Super powerful torque, Adjustable settings.
Hobbywing is recognized as making the smoothest electronic speed controller (ESC) that’s always reliable and made of the highest quality. The Tynee Ultra X Pro uses the latest 14S 58.8V high voltage Hobbywing V7.0 9028 ESC with an automatic on/off function and replaceable hub/belt motors. It can output super powerful torque. So like everything else on this Tynee beast, you can expect the best performance from its ESC.
Two 3000W Hobbywing Belt Motors
Powerful torque, Excellent dynamic balance
Driven by the powerful 14S Hobbywing 9028 ESC, we used two 3000W Hobbywing belt motors. Equipped with the 90A discharge output of the 14S 58.8V Samsung 50S battery, making the Ultra X Pro’s torque easily reach the level of the all terrain electric skateboard. The feeling of surging power will make you feel like standing on a rocket, moving forward without hesitation.
Mobile App
Easy to use, adjust settings in App.
Equipped with a mobile App (iOS & Android), all the settings on the Ultra X Pro can be adjusted easily on your phone. You can customize your riding parameters freely. It’s very simple and easy to use.
Waterproof Battery
Waterproof, dustproof, anti vibration.
The battery is the most expensive and fragile component in electric skateboards, as it can be easily damaged by water and water damage is not covered by warranty, So customers have to pay a lot of money to buy a new battery. Because this will bring higher profits, most brands are unwilling to change. Tynee has decided to address this issue at its root.
Tynee uses the latest waterproof battery design, which covers the entire battery with a special flexible and thermally conductive waterproof glue, providing triple effects of waterproofing, shock resistance, and thermal conductivity. The battery is equipped with the latest upgraded special waterproof membrane on the outside, which has higher strength and better toughness, and can be used for at least 20 years without any damage. Since Tynee released the waterproof battery design in June 2023, even if many Tynee users use their Tynee boards heavily in heavy rain, In the past two years, we have never heard Tynee users complain that their batteries have been damaged by water.
Flexible Bamboo Deck
Comfortable flexible deck. 10 inches wide.
Tynee Ultra X Pro uses a flexible bamboo deck with a width of 10 inches / 25.4cm, which has good elasticity and is more comfortable on bumpy roads. Because the deck is very wide, when you step on it, the contact area between your feet and the deck is larger, making your feet more comfortable for long-distance riding. At the same time, a wider deck can provide better control experience.
9.5’’ Tynee Forged & CNC Truck
Wider truck. More stable at high speed.
The truck of Tynee Ultra X Pro is the 9.5 inches wider truck, and the wider the truck, the more stable it is at high speeds. If you enjoy high-speed riding, please choose the wider truck. And Tynee’s truck has very high strength, which is 2 to 3 times that of ordinary die-cast trucks. Tynee provides a lifetime warranty for the truck.
Smart Turn On/Off
Use your remote to turn on/off the board.
Equipped with smart on-off function, you can turn on/off the board by your remote. When you turn on/off the remote, the remote will automatically send a signal to turn on/off the board. So you don’t need to bend down to turn on/off the board. It’s very convenient.
Boosted 105 72A Soft Wheels
Super comfortable riding experience.
After the bankruptcy of Boosted Board Company, we purchased these wheels from Boosted’s wheel manufacturer and renamed them under the Tynee logo. The design, materials, craftsmanship, and quality are the same as the Boosted 105 wheels, but only the logo printing is different. There are many special holes on the tires, which not only reduce weight but also improve shock absorption. The hardness of the tires is very soft, only 72A, so it is very comfortable.
PACKAGE CONTENTS
What’s in the box?
● 1 Completely assembled Tynee board.
● 1 Smart OLED screen remote control.
● 1 Certified adapter and charger.
● 1 Skate tool.
● 1 Charging cable of remote control.
● 2 Extra belts.
● 1 Manual book (PDF).
Price (USD): $780 obo
Images
Item 2
Description:
Price (USD):
Images
  • upload pictures here
UPDATE - Willing to do $780 including shipping CONUS.
