Unfortunately diy eskates aren’t really for me and I’m looking to part out or sell my board whole. Located in Charlotte NC
181 miles on all components, everything’s basically new except for the davega.
Specs:
Go Foc D100s (qs8 on the esc side) & bt reciever
Efreedom ESC enclosure (55mm height, tapped holes for d100s specifically)
Odachi v2 deck, with double stack enclosure, w concave, and 20mm drop
20s8p eve50pl back made by Jackson Luis, with up to 50 amp charging capability (60a jbd smart bms)
4x MBS Rockstar pro II aluminum hubs in silver, with kenda k909s mounted to all 4 (200mmx50mm)
Linnpower adapter plates on the driven wheels, with 78t wheel (Stooge open spur gear) and 24t motor gearing. (Geared to hit 65ish, has ridiculous torque despite the high gearing)
2x Radium 6485 138kv motors, 8mm shaft, with the ends of the shafts flattened to use standard RC gears (super cheap to replace pinions, which are around 30 dollars for a pair)
Davega X telemetry display
MBS F5 binding in the front (normal ride style)
MAD 3 link trucks
Hoyt ST Puck 2.0
300 dollar aliexpress charger (66-93v 0-50a) pidzoom style with the screen and controls, and an adapter to take 240v EV outlet J1772 to 3 prong USA outlet
Hoping to sell the board as a whole with its accessories around 4k
Open to part out offers but likely will not part out anything until at least the battery+deck is sold first
Deck+binding+battery is a package deal
