Run em on 8mm if u can. The bearings that will fit these and run 10mm axles are not the greatest
Shooting a PM for some.
Does the adapter work for his AT gear drive ?
No, berg isn’t compatible with the AT drive. Way too few use cases to justify.
hmm maybe il get a double set then so i can run 8 and 10
Hi guys, still alive and still have sets left. Will respond as able!
Do you have the 10mm axle version left?
Its the same bracket for both options, but with different bearings. I only have 8mm bearings, and they are uninstalled so it falls on the buyer to press fit them into the adapter(s).
Any adapters left?
same question^
Down to 2 sets left
