Description: Brand new and never used, designed for Funwheel, but can used for anything. I built them to have on hand for my website but nobody’s building funwheels because of the chip and motor shortage. They would be perfect little jump packs for an eMTB.
60A continuous
90A peak (few seconds)
8A max charge rate
8.4Ah nominal capacity
50.4V charge voltage
36V Voltage cutoff end
Daly charge only BMS
Approx. 170 x 142 x 45 mm
I’m new here and can’t figure out how to pay a thread yet, but I just bought a refurbished Meepo mini 2, which I love atm, but I bought it thinking I could buy another battery that fits in the housing with better range than the ER battery.
This one looks like it works, but I was wondering if anyone would point me in the direction I would need to go to learn about this? Also l, if you, the author of this thread are knowledgeable enough about building one of these, maybe I’d be interested in buying one from you so you can make a little as a tip for saving me time and energy? Thanks in advance?
Also, what is the max range a custom Meepo mini 2 battery could reach? From what I’ve seen so far, it would use Samsung q30 cells, but regardless of what cell, does anyone know?
Do you know what range you currently get? The real range of any battery, including what the manufacturer claims, depends on rider weight, speed, and road conditions. If you know what you currently get then we can work out what mileage you get per Wh (the unit of energy in a battery) and give a decent estimate for what the max range would be for a bigger battery. Unfortunately it looks like this battery won’t fit in the current enclosure so you’d need to find something that fits as well.
