Looking for a set of decent motors. Preferably 6374, definitely 190kv and up. Currently have a set of 170kv’s but the torque is too much for my gearing. I’m running 12s Li-ion so not looking for turnigy motors. Local pick up in San Diego would be a huge plus!
even with the adjusted throttle curve? wow.
I’ve got TB 6374s but can’t send them out until Sunday :(.
Got some pictures?
Not until sunday, out of town :(.
No problem. Thanks for reaching out. Happy holidays
Motors are in working order last time I checked.
Pass all hand tests no broken or cracked magnets. Sensors work last time I checked but the connector is shitty (all others from TB like this, what can you do).
One is using janux flux drive can because the previous can had broken magnets. I had to do a shaft transplant. Just added a fresh set of blue loctite and torqued down the set screws. The shaft is pressfit so not much worry there. There is shaft length misalignment between cans (flat spot on shaft), but again, pressfit and I blue loctited the setscrews
Full of grass because I took them offroading. Should not cause problems.
The other has a scratched stator because of said broken magnets (the unscratched stator is using the janux flux drive can, I swapped them) but there is no difference in performance from what I can tell.
They are 190kv. oscilloscope
I can provide two 3mm keys as well.
Selling a bkb motors aka turnigy sk3 with sensors
