[US-SoCal] LLT BMS and Chargers
Selling some old chargers that I no longer have uses for.
Chargers are used but functional. They all have XT60 connectors boardside (If you want I don’t mind soldering a new/different connector)
Buyer pays shipping.
($30) 20s LLT BMS, New in box
Originally bought for Nothing Fancy but ended up using a Neptune 20
New cable, thermocouples, and Bluetooth module
($10) Charger 50.4 4A (12s 200W)
($20) Charger 51v 8A (12s 400W)
I’ll find a ATX cord to include
($20) Charger 72v 8.3A (16s, 600W) adjustable
Here’s a link to the amazon listing
Voltage is easily adjusted with the blue pots
($40) Charger 84v 8A (20s 800W)
Link to amazon listing
also;
Looking to sell my Creality CR6max 3D printer, if anyone's interested in that
Reference image; DM me if you’re interested and I’ll get some good pictures for you.
It’s a big printer!!
Hey bud whats going on listen i have a question for you .The exway x1 pro electric skateboard i have has this weird looking charging port and its only compatible with its own charger …My question is the people that make the eboards why do they do that they use these weird looking charging ports .Question is can i change the charging port and use a different one will it work
There’s lots of different reason’s companies use different charge ports. Charge port selection has a lot of surprisingly complex considerations, including size, current capability, cost, availability, manufacturability, durability, safety, and ease of use. Trying to determine the logic behind exway’s decision is just speculation.
If you wanted to swap it out, any 2-conductor connector that could handle the charge current would work.
It’s not perfect, but a lot of us DIY’ers use XT60s.
XT30 are more than sufficient. (≤30A)
If you’ll be at 4A or less, the 5.5x2.1 barrel connectors are super convenient.
I like the xt60 just because it’s bigger. Not capacity bigger (though it is) but just physically larger and easier to handle. I tried the lp20 and it’s just too big. Need that good mama bear middle ground type connector - xt60h for the win
I use the other end of the xt60 on the charger. keep the board side from getting shorted easier.
And i just make xt60 to whatever adapters. LP20, LP16, XLR, DC5.1 weird backfire hammer connector, …
