Time to clean house and make some space. All parts are used except the majority of motor pulleys. Shipping is not included in any price, but depending on the item make me an offer and I’ll consider it.
Motors
6485 SKP, 151kv (Reacher) Sensored Motors - I previously posted that the sensors had been fried due to a Ubox malfunction
, but upon further review I’m an idiot… I just forgot reacher motors swap the colors on the ground and temp wires, so VESC wasn’t seeing them and neither was my $8 ebike motor tester. I’ve already bought some replacements so these are currently extra. Therefore, I’m changing the price on these to $225/pair. SOLD
65102 Bioboard, 138kv motors - About 1000 miles on them, but still have great performance. I use them for testing now, The stators and sensors were all dipped in epoxy and the cans have an extra couple millimeters of thickness for durability. I can leave the cnlinko hall connectors or swap them to JST (your choice) $150/pair
6485 Boardnamics (Flipsky), 190kv - Just the single motor. Got this motor thrown in when I bought some other parts. The can is pretty beat up, and the shaft was cut down for a Boardnamics M1 gear drive, but the motor doesn’t have many miles on it. I’ve tested it and it runs perfectly on the bench. $50 for the SINGLE. SOLD
6355 BKB 190kv - These are well loved with a lot of miles, but have been freshened up with all new bearings. $60/pair SOLD
Next up are a bunch of mostly new, mostly 8mm bore, steel pulleys for $15/pair including 14t from boardnamic with their m3 grub screws. The used and aluminum pulleys plus the 20t, 12mm D shaft pulleys are $10/pair. The aluminum 14t, 20t, and one of the 15t pulleys are 10mm bore, those are $10 also. If they’re not crossed out below they’re available.
Now for the wheels and tires:
Original Rockstar Pro hubs - $50
Still in very good shape and your choice of 10 or 12mm rs BEARINGS - SOLD
4 Primo Striker, 8 inch tires and tubes - $35
4 Trampa Hypa hubs - Matte black plus two 65t bearing pulleys $80 (all hardware, bearings and spacers included) - SOLD
Or take tires, Hypa hubs and pulleys for $100.
