Quoted
Quoted
For the record
I don’t hate you man
In fact. I’m having so much fun with those vescs. They are confidence inspiring
For the record I don’t hate you man
Just launch the dam things already.
Bump.
Battery pack sold!
Adding raggedy Lacroix 6396s. Yes. 6396s 190kv motors.
Around 200 miles on them
One of them work perfectly fine. The other one works but makes a rattling noise at around 30mph therefore I’d only recommend using it for parts
Pls note that these motors will only fit Lacroix motor mounts due to them using the small hole pattern to bolt on to the mount. And for that same reason these motors won’t get decapitated like maytech branded ones with standard hole pattern did
10mm shaft
12ga leads about 12 inches long with 4mm bullet connectors
Sensor wires with Standard 2.0mm connector
Asking $125 for the one that works good and throwing in the shitty one in for free
Vanpro remote. Not a whole lot to say about it except for that I’m scared to death of these things lol.
Same as the mini just different shape with rechargeable battery
Pretty much new $15
Just circumstances to a resurceful guy with a sharp mind and the help of a few mount manufacturers willing to jump in with a custom job… @Janux-esk8, @ATC, @IDEA, etc.
I can difffenty take the bad one off his hands and accommodate the hole pattern in my mounts I already have.
karamdibs.
Gone BUT @fessyfoo being your neighbor can definitely let you borrow the face plate of the motor for measuring purposes
In fact. They’re nothing special.
Most 6374 motors have both hole pattern. Lacroix uses the ones closer together
30mm… TB Also has these as an option.
These motors sold?
If not I’ll Take em.
TNX
Moar Chet
Gotta clear out some stuff
Sold as a lot. Won’t part out so pls don’t ask
SOLD!!
4 berg hubs in black NEW
20 berg tires NEW
34 inner tubes “a hand full of them lightly used most NEW”
$300 for the lot plus shipping I’ll eat PayPal fees
Why do you have so many!?
Stole them
Lmao. Jk. I freak out about not having spares. Plus A few sudden change of plans
Haha that’s fair
Damnnnn if I could find some 12x22 bearings that can go on these with MBS trucks, I probably would scoop them up.
Lmao. Non existent unless you buy form esk8 castle or whatever that company is called
Hit them up. It’s worth the try
You have a link?
