(US) can ship worldwide other then batteries. All prices are in USD, don’t include shipping, and are OBO. PayPal, venmo, zelle accepted(please include fees upon payment if using buyer protection)
Radium 205 kv 6485 motors x2 (batch 6)
Summary
340$
300$
Ran once, decided to go different kv. Some scratches(just cosmetic)
SOLD
Summary
Malectrics spot welder + 2x turnigy rapid 3s2p 140c batteries
145$
TURNIGY RAPID 5500mAh 3S 11.1V 140C LIPO BATTERY HARDCASE XT90 ROAR RC ARRMA | eBay
Used for three battery builds, lipos have about 5 cycles. Both, in parallel, work great. However, one isn’t quite enough power unless using nickel on the thinner side. Decided I’d rather pay a pro for any future batteries as I don’t really like doing battery work and have a turtle pace. I learned a lot though, so happy for the knowledge I gained. Includes fireproof bag for lipos
6x zee 6s 100c 6000mah lipos
Summary
50$ each or 250$ for all six
45$ each, 225 for all six
Zeee 6S Lipo Battery 22.2V 100C 6000mAh with EC5 Connector RC Battery for RC Car Truck RC Airplane Helicopter Quadcopter Boat (2 Packs) https://a.co/d/53pZKFe
Have about 3 cycles on them. Just used for two or so rides. Two of them have anti spark xt-90’s the other four have knock off xt-90’s. They’ll come with fireproof bags unless you you buy and odd number. Then it’ll depend on if any are left. Can send you some more genuine xt-90s if you want.
Random rear 1500 Whatt 700c 6speed ebike hub motor
Summary
50$
40$
Was going to use for an ebike build for the misses, ended up going a different route
Random light
2$
Summary
Spintend, ubox 16s esc with remote
100$
Ran for a little bit, no issues with the esc itself but the built in receiver the Remote I’ve had issues with(sometimes I have to repair with remote after powering on). Remote squeaks as well so maybe lube the throttle, replace, or use another remote. Older model with micro USB ports
Fishpaper with adhesive brand new
5$
8" Kenda tires with tubes new
55$
Random hunting kneepads/elbow pads New
15$
They’re plastic so should slide
Landyachtz evo 40 deck
70$
Not used too much but grip tape is messed up and has a couple random holes drilled in
Wire stripper up to 10awg New
5$
Bought too many wire strippers
Radium 16s 10amp charger with this connector attached
SD20 2pin Waterproof Connector, Circular IP68 LED Solar Panel Power Cable Plug Heavy Industrial Connector (2pin, Panel Mount) Amazon.com
Summary
95$
85$
Soldered US plug on, can send original plug as well
Random AliExpress 16s 10 amp charger
Summary
18$
15$
Cut off the the plug to use for the radium but realized the ground was fake. Reattached later. Charger works but only outputs about 6.5 amps vs the claimed 10amps. Use at your own risk and swap the barrel for something that can handle 10amps.
Venom, two channel lipo+ balance charger
Venom Power - Pro Duo LiPo Battery Charger with LCD Screen - 80W X2 AC DC 7A NiMH LiHV LiPo Balance Charger Discharger with Charger Adapter - LiPo 1S to 6S, Drone, RC Car Battery Charger https://a.co/d/c6cmnWy
75$
Includes pictured connectors. Works great, has a multitude of functions and works with several chemistries.
Zee 3s lipo
20$
Has 5-10 cycles on it, perfectly balanced
Copper braid 1/4" + 1/2"
Summary
8$
5$
Random hangers
10$
Hobbywing Lipo Parallel charging board
10$
SOLD
Summary
Mbs binding(regular) new
35$ or trade for goofy
Lost original nuts/bolts. Added some slightly longer bolts and nuts. Never used.
Flipsky AT trucks 10$ + hubs 10$
Or take both for 15$
Not used too much
Fluxmotion enclosure with heatsink
30$
No mounting hardware included. Has seen some use. Now using a different enclosure with the deck
Hexfly 2s, 3s lipo balance charger
Summary
10$
5$
Newbee 4gs 44/11, 8mm keyway, apex air, Luna350, rtkp
250$ or trade for older helical 38/11
Unused, test fitted the wheel plate to a few things and it got dinged up a little when I got it stuck on something. Other then that the rest of the components are mostly untouched. Was going to run with 3-links with savage1 adapter, but the adapter he sent doesn’t fit and can’t really get more then two mounting holes no matter which way I put it. I’m guessing it was fitted for the older, helical version/the 38/11 helical has a different mounting pattern. Either way, don’t have much of a use for it as the plan was for 3-links
SagacustomRC mod 1.5 8mm 29t (to use with sbr open gear drive)
20$
2 pinions, new
