[US] Esk8 Gokart (WTS)
Electric live axle Goped Goquad For sale, asking 2200 shipped.
Top speed: varies between 32mph and 30mph with alot of torque. depends on rider weight and voltage I’m 270.
Range: 15 miles with a 270 pound rider.
It has a metr pro blue tooth, can be used to track data and map out ride, also to change modes. You can have fast mode, eco mode, 10mph kid mode.
The motors are two Torque board 63100 165kv. The sprocket ratio is 4:1, so the motors each have 14 tooth sprockets and the wheels have 56. Want more top speed change the motor ones to 16 and try upping the motor amps to make up for lost torque.
The controllers are two vesc 6 from torque boards on a fat heatsink to help with cooling.
The throttle is two way, so you can accelerate and use regen braking. Regen braking works very very well, but I still recommend you install a mechanical brake on the front wheels eventually.
The Battery is a 12s4p molicell p42a built from skyart power. It is a great battery should last a long time. Has a smart Bms, so you can see the battery temp and the individual cell voltage. Will come with a 4amp charger.
Brought the frame used and had it powder coated, not perfect but rides great.
Has ada billet wheels infront and in the back.
I designed the battery box (petg material), motor mounts and battery box plate. The light does not come with the kart. If you ever break electronics the motors and vesc can be easily replaced or upgraded. This gokart is very very fun, only reason I’m selling is because I don’t use it that much anymore, need the extra cash and want to buy a 18s battery. If you have any questions message me!
Bump, priced reduced to 2200 shipped !!
