Brand new Lacroix 6396 140kv motors 10mm bore, the bolting pattern didn’t work for me. Take them both for $75 with shipping. (Sorry @poastoast, I wish they worked for me, I am very appreciative of your kindness.)
I believe there’s like some sort of adapters that could change the bolt patterns
I’ve looked, can’t find any ![]()
I got them for a good price and would rather keep the mounts. The only other option I’ve seen is getting the prototipo trucks from lacroix, but considering how cheap I got the motors, selling seems like the best thing to do
LaCroix went out of business, you can’t currently buy anything from them.
The trucks on the prototipo were made by MBS mountainboards they’re called matrix 2s and can still be purchased today on MBS’s website you can also buy the newer version, the matrix 3s
I’m not suggesting you do as I don’t think it would solve your issue but for the sake of clarification.
I have pair of matrix 2s, and idea mounts. I had assumed the 6396s would be compatible but they aren’t. Now I am looking at other options. Keeping the mounts though.
Hey - i have the same issue but i am designing an adapter. If you want, i can share it for free, you request your own at a machine shop - like pcbway, jlc3dp or any other.
But this will be only ready by early Jan though.
Fessyfoo was selling some adapters until about a month ago, check what those look like.
I’m pretty sure those motors are made by Maytech and the ones from Maytech have the inner holes countersunk, the outer ones holding the motor plate thing so if you countersunk the inner ones and got some screws you could use the outer ones.
I put the 2 side by side to hopefully help explain.
Hmm, that’s interesting.
which idea mounts? if they’re long slots… you can can twist the motor so two bolt holes align and just use two. YMMV.
alternatively I think i’ve seen people have the 40mm bcd drilled and tapped into those maytech/lacroix motors if you got a cool machinist around.
They’re an older version, I got one to fit in the correct bolt hole, even then the shaft wasn’t centered. And no, sadly I don’t have a machinist around
Bump. $70
DM sent.
I would be interested in these as well! Lmk if you don’t sell them.
Anybody?
