Urethane Heat Sinks
Why not? No seriously. If you don’t have the time or ideas to manufacture it, why not sell the baseproduct and let the people do it themselfs.
Your results may vary…widely. The urethanes we use require a lot of specialized equipment and to process them in a low tech environment takes years and years of experience and a lot of trade secrets.
Ok, so i guess it will go down the road like the RipTide Tunnelriser?
Something that alot of people can get behind, like a groupbuy and you guys make it. Is that something you can get behind?
Yes definitely, there needs to be a problem to solve before we build the solution and you guys know best!
Alright. Frome the top of my head i think of something like NESE modules but instead of using pressure to make contact we could still use normal welds and put Parallel Groups of Cells in a case…
I will CAD something up if i have time to better illustrate what i am thinking.
maybe computer motherboard parts heatsinking?
Is this after it cures? Or the entire time :thinking:
Entire time
Thanks for the speedy reply!
There must be some mistake. ur not going to transfer heat at 83% the ability of aluminum with a filled pu. the link you posted had the best conductivity of any resin I’ve seen at 7% the conductivity of aluminum no?
I have stated what I found, perhaps my interpretation of the data is incorrect but if you have an application you want to try it with, let me know. The end product will determine if what I have found is useful or not.
