Under_voltage error unity
Guys
Sunny day, so charged my emtb a bit more (was at 50% when i started).
When i was checking the batt % a little later, i got a fault under voltage in my unity app.
Did guided setup again , failed at motor detection. Ok weird. Ignore.
Reflashed the firmware (2 times) and ran guided setup again, this time with no wheels. Still under voltage error and i still can not get the motor test done successfully.
Turned off the unity (“hey, never noticed the power button flashing 2 times when turning off the unity”) and now… It doesn’t turn on anymore.
Worked like a charm last Tuesday. Stored inside.
Any suggestions?
12s7p, unity running conservative settings . 6880 engines
3d servisas heat sink and yes im using his power button.
Firmware reflashed with oem unity firmware. Twice.
Guided setup done. No change.
Turned on and off the unity like 2 or 3 times in the process. Now doesn’t turn on at all.
I have some other unities i can most likely remove from other builds and test it out. But that won’t be today due to outside obligations.
Any suggestions?
@mackann its one of yours :slight_smile: just a heads up haha
Damn thats the wrong screenshot hahaha… Oh well…
So yes… Im now going to check the other one… Fingers crossed
Edit:fieuuww :joy:
Issue found
Not sure if it was already there (and the reason of the fault code) or caused by the firmware reflash, but it went boom. Just opened it up :frowning:
Nothing special last time i took it out for a spin
I bet everytime time Jason does a poo, a unity takes a shit.
@mackann just in case you have a ton of pms… I sent you a pm for the above, plus an email to order@bio…
If you can take a look and maybe just like my pm so i know you have read it… Thx
(edit: email fwd as requested, thx)
