As the title says, looking for some 6374 to 6384 motors with 8mm shaft, preferably sensored but pretty open to see what’s around!
Many thanks
Many thanks
I really like my 6374 battle hardened motors that I got from @Anubis ![]()
FS 2021 6374 3500W 170kv Battle-Hardened Motor – Nexus Boards
He needs them for boardnamics GD so i think the stepped shaft means it won’t work
These may / may not be for gear drive but I did ask Kevin @Boardnamics and he said the flipskys should fit the gears fine - next time someone asks, it looks like you should sell away
We need to do some homework on this because I want to get those GD eventually
@Boardnamics or @KaramQ or @Bobby what motors are you using on your setups
The man himself.
Yes this is good but pics to confirm this would be even better
If you want to buy aps 6384 with 10mm axles, I have two 6384 stepped down 8mm axles that I can sell.
So just to clarify I have two 8mm axles for 6384 motors
This does mean you’ll need to remove the shaft though and this is a bit of work
I’m using 6355 Tb motors on his 220’s
Thanks for letting me know - I will see what comes up and let you know!
Step down axles work fine as long as the stepped portion is 7mm or less in length.
Using 2 6374 motors on boardnamics 220’s…
If 6380 fits, it will be a very tight squeeze
Fair, I will be sticking to 6374 then!!!
The Tb 6380’s will work, the sk3’s are more then xx74
Looks like it’s 8mm
(thanks @Anubis for the image)
ouch…so the FS won’t work with @Boardnamics GD’s…or at least they might work …?
They will. The distance between the plate and wheel gear is 0.7mm, so if the motor gear is 1mm away from the plate, that will have no adverse effects on performance. 0.3mm less width engagement is unnoticeable.
The motor gear is 1mm away because the plate is 7mm thick.
