Here I am again trying to straighten up my life by getting rid of some of my precious swag
Please read. I have new and used shit I want to sell.
Located in San Jose ca Local pick up is available
Motor pulleys
-SOLD New steel 16t 8mm bore with keyway “torque board brand” x4 $14 each set
-New 18t steel 10mm bore no keyway x2 $12/set
-SOLD! New 18t steel 8mm bore with 3x3mm keyway x2 $ $14/set
-New 20t aluminum 10mm bore no keyway x2 $8/set
-New 20t Aluminium 8mm bore no keyway x2 $8/set
-Used 20t Aluminium 10mm bore no keyway x2 $7/set
-Used 18t Aluminium 8mm bore no keyway x2 $7/set
-Used 16t Aluminium 10mm bore no keyway x2 $7/set
-SOLD! Used Metroboard 36t Abec Aluminium wheel pulley set. Will support 20mm wide belts
Personally I think this is a clever pulley design only problem is that it requires extra axle length “Tb 218 trucks will have barely enough axles to support this pulleys” will work perfect with boardnamics trucks $13/set
-SOLD! Used haggy boards 36t abec wheel pulleys Bearings not included $12/set
-A few belts available. Everything 5m 15mm wide New and used $5 a set “2pcs”
-255 x2 new
-270 x2 new
-SALE PENDING! 275 x2 new
-SOLD! 280 x4 used in good shape
-285 x4 new
-290 x2 used in good shape
-295 x2 new
-300 x2 used
-305 x2 new
-310 x2 new
-320 x4 new
-Evolve gt -001 x2 used “will fit evolve AT setup”
Are the “new steel 16t 8mm bore with keyway “torque board brand” x8 $14 each set” compatible with a 15mm wide belt? If so, I’ll take a set shipped to 97404.
