If this is in the wrong place pls move it. I’ve wired in the above switch however I have as an option the side that goes to the load can be unplugged. However I need somewhere to plug it back in when not in use. Is it ok for it to go to the positive wire that is also connected to its other terminal? See below diagram
First you draw two circles, then you draw the rest of the diagram
it’s not letting me upload a pic unfortunately
Ok so for some reason I can upload this but not the edited one. Imagine no load and both positives on the turnigy connected to each other
Never messed with a turnigy but it may work.
I’m confused to what youre really trying to achieve though?
I have a 12v output on my board which is on all the time so I can use it when the board is powered off. The lights are wired from the 12v buck converter but with the turnigy in series which I use when the board is turned on. Basically the load output from the turnigy isn’t plugged into anything when I remove the lights and I’d rather not have it knocking around
