I am trying to swap out from boardnamics gear drives to Newbee 4GS and I cannot get the boardnamic truck clamp off. I have tried hammering it off, wd 40, everything I can think of. Any suggestions?
FWIW it was installed with no type of adhesives. Just metal on metal
The hanger is aluminum as well, it will be of no use to heat it up. I have had success getting stuck adapters off using an arbor press and pressing the axle, with the adapter against the base.
UPDATE: I appreciate everyone’s feedback. A buddy of mine had a bearing puller and was able to remove it for me. It is now off and the Newbee 4GS’ are now installed.
