Hey guys!
Today my cheapFOCer v2 stopped working flawless.
Vesc terminal prints the error “FAULT_CODE_HIGH_OFFSET_CURRENT_SENSOR_1” and neither Hall-Sensor detection nor Motor detection are working anylonger, so that the Motor does not spin at all anymore.
There was no incident or anything strinking.
I unpluged any cables, reinstalled 5.2 stable firmware, but the fault LED is still blinking and the error is still active.
That needs to be repaired, there is no way around it.
Luckily, there is someone in DE who can do that service, @seaborder, although I don’t know if this product has enough worth to make repair costs feasible.
Basic solder skills won’t do, as the pins are extremely small and there is a ground pad on the bottom of that IC you can’t see.
If the traces are blown off, there is a chance it’s not repairable. Can you send a high-resolution image of that spot, and check for any burn marks elsewhere on the entire PCB?
i think you shorted out the pins on the drv (Solderball etc.), those pins go directly to VSupply and GND, this created a bad short. The pads are gone but its fixable with a little bridge, also need to check shunt amplifiers and overall components
The cheapFocer2 uses the 2 built in current amplifiers of the DRV8301 for phase 1 and 2. There is only 1 visible external Op-amp on the PCB sensing phase 3.
Fault on sensor 1 should indicate that something is not ok with the DRV itself (unless it is a continuity issue).
As @doomy said, pins 30-33 should be connected directly to the shunt resistors. Since these resistors are 1mohm, it will look like all these legs are connected together (which they are not!) in the cheapFocer2.
In other escs these legs are connected together to disable the internal shunt amplifiers (Schematic attatched by @seaborder) They all have 3 external amplifiers on the PCB. But not this esc.
I have put plenty of km on my focers and to avoid DRVfaults, 65A Motor is the highest limit where I can run with zero faults. My opinion is to not go above.
