New beast on the block.
I really like the shape, there’s a competitor to Kaly now.
CROSS COUNTRY ALL TERRAIN - GEN 3 - (2WD and 4WD)
THIS IS OUR 3RD GENERATION IMPROVED VERSION OF OUR BEST SELLING BOARD TO DATE - THE CROSS COUNTRY
LOADED WITH ADDITIONAL POWER AND RANGE THAN GEN2, THE CROSS COUNTRY GEN 3 ELECTRIC SKATEBOARD PROVIDES A VERY FORGIVING RIDE FOR ALL LEVELS OF RIDERS.
STABLE, POWERFUL AND FUN. GREAT FOR OUTDOORS AND OPEN SPACES, THE BIG 280 MM AIR WHEELS WILL OVERCOME ALMOST EVERY OBSTACLE ON THE ROAD.
NEW FEATURES ON THE CC GEN 3 INCLUDE AN IMPROVED AND RELIABLE ESC, UPGRADED REMOTE CONTROL, HIGH QUALITY BATTERY (SAMSUNG 30Q - 10S5P), FLEX BATTERY CASE AND REDESIGNED SPRINGS ON THE TRUCKS.
CROSS COUNTRY GEN 3 SPECS
2WD:
- Max speed: up to 38 km/h (*)
- Max travel range per full charge: 25 - 30 km (*)
- Motor type: Brushless N63 motor
- Motor rated power: Dual-motor, 1650 W each (total 3300 w)
- Regenerative brakes
- Wheel material: Pneumatic tire
- Wheel size: 280mm x 90mm
- Battery: Lithium Ion, 14Ah, 10S5P SAMSUNG 30Q
- Charging time: 3-4 hrs
- Battery cycle life: Above 1000 times
- Board material: 2 layers bamboo and 8 layers maples
- Board Size: 115 x 42 x 23 cm
- Packaging size: 122 x 47 x 27 cm
- Gross weight: 19kg (inc box, battery, remote control, etc)
- Net weight: 15kg (skateboard only)
4WD:
Comes with 4 hub motors, powered by a 10S4P Samsung 30Q battery (12Ah), connected to 2 ESCs. This is a powerful board, will climb almost everything and overcome most obstacles. Faster acceleration and break than the 2WD. This board will provide around 20 - 25 km range. Also available on 10S5P (15Ah) for additional range (up to 30km+), this is our 4WD Plus.
If you have specific requirements for the Cross Country, we can custom made one for you!
(*) under optimal conditions. Maximum speed and endurance could vary based on type of road, weight of rider, riding style, road inclination, etc.
(from downunder)
