In order to avoid any confusion in future, Vedder updated the README file. I hope that it becomes more clear now why things are the way they are and what the does and don’ts are.
VESC® Tool
This is the source code of VESC Tool. A pre-compiled binary of both the stable release as well as the development release packaged with all the matching firmware for all supported hardware can be downloaded at http://vesc-project.com/
The stable binary is available for Linux, Windows, MacOS, Android and iOS. The development binary is available for Linux, Windows and Android and is updated every few days.
All binaries can also be downloaded free-of-charge for all platforms except for iOS, which only is available via the Apple App Store as they do not allow any other distribution channel.
## Code Contribution, Distribution and Trademark Usage
VESC is a registered trademark of Benjamin Vedder. Read the trademark policies for more information.
The “official” binary release of VESC Tool is done via VESC Project only, as that gives users a way to verify that releases, that use the registered VESC trademark, originate from the VESC Project. It is not ok to host a binary release on a different channel and use the VESC trademark for that release.
It is ok to use the github fork function to make contributions to the code. That is because 1) it is the most convenient way to make contributions and 2) the forked repository states clearly that it is a fork and points back to the main repository where the original code can be found. Further, it is easy to see what the code changes are from the forked repository compared to the main repository via github, but that information is lost in a binary release.
Forks of VESC Tool on github are not encouraged to provide a binary release in the repository. That is because there is no way to tell the final binary apart from the official release once downloaded. Further, packaging the firmware, which has to be done as an additional step from a different repository, also cannot be verified whether it is done correctly.
## Add Your Hardware to the Binary Release
If you have custom hardware and you want to add support for it in the official release of VESC Tool, you can use the following steps:
1. Go to GitHub - vedderb/bldc: The VESC motor control firmware and use the github fork function.
2. Make your changes, test them and make a pull request to the main repository.
3. If the pull request gets accepted your hardware will become part of the next official release. It will show up in the binary beta typically after a few days and in the stable version the next time a stable release is made.
