This is a silly question, but I not sure why when I enabled traction control using the setup Wizard only one of my motor has traction control enabled and the other doesn’t?
Should not both motors has traction control enable, or it is only needed on the primary side.
I’m using Go-Foc DV6 ESC.
Traction control needs to be activated on the side holding the remote receiver. Only works over canbus, not split ppm.
One good way to check is by holding one wheel and gently accelerating. The other wheel(s) will spin at the max erpm difference, which is 3000erpm by default
Just leave the default honestly.
Main purpose is to keep traction when braking and to not fling mud at you when one wheel loses traction in thick mud.
Only reason you’d decrease it is if you want more power to the inside wheel when cornering, but that’s a difference of under 500erpm which would need 1000erpm to apply 50% less power to the outside wheel. Default works just fine, won’t spin out if a wheel lifts a bit
