Wow does torqueboards ships a free enclosure with every deck purchase? Or is that all custom work with a torqueboards sticker? Its great either way!
It’s been a while since I’ve updated this thread!
After a long series of 15-20 mile runs on a carver I took this board out again tonight and was reminded A) how scary it can be and B) how much fun it is on a track.
The enclosure was upgraded swapped for a prototype Dexter sent out for testing.
I put in one of the Toughwire Antispark units and it’s been working wonderfully. I like the push to start feature but wish it had come with a button sometimes. Not enough to actually install one myself if that tells you anything.
I’ve only really come across one QC issue while testing a TB6 and I see it’s already been addressed in the current units that are making it out into the wild here and there.
IMG_0516
I had to apply more loctite and tighten one axle that started backing out. I brought it up and see it’s happened a time or two to others. Still, it’s a good idea to check your stuff every now and again.
No bending of the long motor mounts with cross braces installed but I’m keeping an eye on them since it has large motors.
Hoping to get my hands on some of those giant wheels @torqueboards has in the works
The sidewalks here are just too brutal for this rig and the streets are slightly sketch but it still gets out
That first enclosure was the ducks nuts
you’ve inspired me to try a new method for making my next enclosure buck, thanks!
Wicked! Any time
really nice clean build
where did you get the vescs from?
may you share the vesc settings on those motors? would be really nice
Thank you! I’d have to pull them up again. Pretty sure it’s mostly the default settings and maybe dialed down the amp limits a bit.
TORQUE ESC V6.64 - High Mileage Immediate Testers
