$110
-Located Seabrook NH
-local pickup preferred -
Tomiboi Liquid Sword 38" drop deck
Dried Blood wood color
clear glass frit
flex level 8/10 my own subjective rating. Say a Loaded bamboo flex deck is a level 1 and a carbon tub board like a meepo hurricane is a 10 for stiffness. It definitely has a small amount of give to it to absorb some road vibrations, but is still very solid. 240 lbs with gear on for me.
Mrsp deck - 430
Marl deck + doublstack enclosure $595
Because the enclosure has already been drilled out. I am including it for free as it may not suit everyone’s style.
I printed fresh TPU plugs to go with it if you’d like to use them. I included a picture of how I set it up. Personally I felt that this was fairly splash resistant and wouldn’t care if I hit a puddle. I never found traces if water in the enclosure. If you wanted to go for full waterproof, I would silicone around the wires.
The enclosure cutout is for a bioboards heatsink. Their heatsink sits snugly and can be installed with silicone to be water tight. The bioboards heatsink fits a good variety of the current vesc.
There are also holes for a power button and charge port. I can toss in the charge port that I used rated for 12A. Also I can include the a printed heatsink slider (as pictured from my setup)
The gasket on the underside of the deck is a little beat up. You can buy a sheet of adhesive closed cell foam on Amazon for about $15 and redo if you think necessary.
Let me know if you have any questions about the deck or about a build you are working on. Happy to help Please post in one of the subcategories instead of posting directly in here. Thanks!
