Tipsy's Summer Sale: wheels, trucks und more
Prices do not include shipping and G&S.
Located in Israel.
Shipping fees are pretty flat and don’t go up much with weight.
Eboosted enclosure - $75
With rubber gasket.
Newbee RTKP Truck x1 - $80
One grub screw is stripped, so treat it as permanently fixed axle xD
Sold:
Trampa IR + OBD mounts + 66/76 pulleys - $320
Basically a complete drivetrain with a ton of gear ratio options, just add motors.
Half price of what it costs new from Trampa.
  • Trampa IR trucks.
  • A pair of both 66 and 76 teeth wheel pullies.
  • A pair of 14 teeth motor pullies with keys and set screws.
  • A pair of idlers.
  • OBD mounts, 66 tooth (shorter) version. Will fit 76 pullies, but without the idlers.
  • x16 belts, a mix of 415 and 440, for both 66 and 76 pullies (most are new).
  • All bolts and some hex spacers that might or might not work for your hubs.
  • Default Trampa bushings they came with.
Trampa phatlads x5 - $55
Mad 105 wheels - $75
Used for about 20km.
TB110 wheels 72A - $50
Hoyt puck bamboo - $80
Riptide bushings - $60
Krank formula. Some are used, some are new.
3DS kegel pulleys 44T - $50
Unobtanium xD
44T, 15mm wide.
Hey! I would love to buy Mads, how can I contact you?
The enclosure for what deck is it?
“universal 12s” so most flat decks but it’s the Sector 9 Bintang
Do you think a 12s4p 21700 will fit?
I think it’s designed for a 12s4p 18650, I have the half length version on my Pranayama and only packed a 12s2p 18650 and a Unity in there
I have fit one in there.
Oh yes now I remember, you can’t do it with 21700 cells and have a smart BMS, you have to pick between 18650 and an LLT or 21700 and a DALY
Dimensions are in the photos.
This is a custom version and it’s smaller.
Will not fit 12s4p.
Looks like a useful area of about 130mm by 430mm, no chance of running 21700s perpendicular to the deck but you could probs pack a 12s2p 18650 (6 wide and 4 long) without issue
Is that custom or is it the 18" cruiser option? If so I have that
18" cruiser enclosure, but custom sized:
Fits no problem:
Did the mod make it bigger or smaller? Dry 21700s fit perpendicular for sure but with all the other thickness from making it a full battery the 18650s are a bit snug already
Bump.
Price drops on everything.
Added Trampa IR+OBD and Newbee RTKP.
Bump.
Puck and thane wheels sold.
Bump and price drops.
bump
