I am currently trying to cram 4 ESCs, a 10s7P battery, an anti-spark plug, and some other weird stuff into my current project and I decided to turn to the forum.
I know you guys have some advice for making 10lbs of tech into a 5lbs deck.
Although it will be less convenient if you want to re-purpose the ESCs, you can save space by splicing and soldering the power cables together which would let you remove those bulky 2 to 1 adapters. EDIT: What said
I recently got a davega on my board and found that all my xt90s are completely unnecessary.
Xt60s save a lot of space, it could be worth your time to swap the vesc xt90s over, while still keeping the battery xt90 as well as the main splitter connectors
I’d circle what I’m talking about on your photo to be more clear but quite honestly I can’t tell what’s what
Right on I’ll look into how to do that. I bought them pre made.
That harness was build when I thought the esc’s were going to have to be closer to the wheels, before I built the harnesses to extend the phase and sensor wires.
